FK-503 Memory Module
  • mrfuser
    • 1605
    Does anyone know what the add on memory module for the FK-503 is called? I can't seem to remember and i know you need it to activate network fax option.
    Thanks all!
    Kelly
  • emujo
    • Jun 2009
    • 3009
    The FK-503 comes standard with a 32MB mem module, EM-303,304,305 are upgrade memory 32MB,64MB, and 128MB respectivly. We had a ton of extra 32 mb chips as the sales people would always purchase the extra chip, blissfully unaware that the fax came with this. Emujo
    • aleksander
      • 378
      Thanks all!
      Kelly
      you need SU-501 to activate the network fax.
      • bronco31
        • Aug 2009
        • 174
        im also mixed up.. so the fax "card" has 32 mb built-in right? ( mounted closeset to edge of main board i believe)
        do we need another SU-501 (32mb mem) ?
        which goes where?
        Guy
        • Hansoon
          • Sep 2007
          • 3371
          The "Fax" module is the left one with the 4pcs chips going in slot marked "A". The one in slot "B" is the memory module.
          SU-501 is the left module which comes with the FK-503 and has 32mb memory. It allows also for IP-Scanning. In case slot A is occupied you have to replace the existing module with the SU-501 module. Slot B should always have the memory module with the 3 chips shown above, otherwise is printing not possible. Networkfax is a software application. Until now only for XP. For W7 I haven't seen it yet.
          Hans
          โ€œSent from my Intel 80286 using MS-DOS 2.0โ€
