How do I record "L" adj into NVram ?
Konica 7130 pm procedure
You must enter 36 mode, High Voltage Adjustment and execute the L detection adjustment.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
Yeah I did & it said result ok. I turned it off & on. Made a self generated print out & it jammed. I Clnd rollers & path. Gave me 1 complete copy. I made a copy this time. Then F-26-3 started. The only way I was able to clear that code was not to turn off & back on but to redo the whole counter resetting proceedure. Then runing "L" again. Now it codes out every time u turn it on.
Most important. How to record the ATS reading into NVram ??Comment
The result is recorded into NVRAM every time you do the L-Detection. You either got a toner sensor problem or a toner feed problem.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
