Chip Ressetting
I checked out Lapatushka site and didn't see anything there referring to the DSQ8. But strangely he list the C250 and the C350 with the same programmer? Anyway Peter if you could send me a link to the reference for programming the DSQ8 I would appreciate it.
ThanksOnline Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI BoxesComment
elton
hi elton here i have a resetter for the 250/252/300/352/450/350/2203 any way i can reset all the machine except the newer models if u r interested pls let me know my email is elalex30@gmail.comComment
elton
vdwind
If you go and read the device datasheet, there is clearly said that once write protection flags are set to AA or 55, they never can be modified. They are one time set only - and these traders who offer here resetters that reset "everything" are LIARS !!!!
You can use their software and resetters only if you have non write protected chip with secret free to change.
Tested and NOT 100% working !!!Comment
You are absolutely correct. But the chance of using the chip in the same machine it was removed from are slim unless of course you only have one machine, and as long as you only re-chip once and then install a new IU then the chip is usable again.Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
kmchips
Konica Minolta Reset Chips
Australia & New Zealand!!
Kmchips.com has Konica Minolta C203 Reset Chips As well as many others.
Konica 8020 & 8031 Chip Files
Hi,
I would greatly appreciate some help with these questions.
Could anybody help with the data file(s) for writing the Imaging chips?
Has anyone used CF3102 units in a Konica 8031 after exchanging chips?
Many Thanks
PhillComment
I used to work on a KonicaMinolta Dealership that used to reset chips, IMHO it is a waste of time and resources, you might be able to use the drum a bit longer but the copy quality starts to deteriorate quite a bit, you'd be lucky if you get a decent copy 1/3 of the way after the chip is reset, I dont remember the name/brand of the device they used but to me it is a Waste of Time/Resources and possibly loss of a clientComment
Re: chip reseter
For C250 and c 550
Ok I buy the chip reseter then I reset the tonner chip and refill them; then the the image units .
But I want to find the folowing:
where I can buy tonner for refil an drums(or a rebuild kit) for image units because a image unit can last for ever!
Tanks:
So for the c 550 I bought my resetter from www.kopy-kat.com/C451_550.html and the toner I buy from either ebay or AAA toner.Comment
