Scanning on Windows 2010/ 7 / vista
  • punchi.com
    • May 2025
    [Misc] Scanning on Windows 2010/ 7 / vista
    has any one got the procedure for setting up scanning to FTP and SMB for windows 7, vista and 2010? tried many ways but can't get it to work, XP no a problem?
  • CT Copier Repair
    • Mar 2010
    • 304
    yea use xp
    7 is a nightmare have the customer setup an old workstation and make it a scan server
    • mrwho
      Major Asshole!
      • 4299
      If you're trying to use Konica's FTP utility on anything above XP, then that could be the cause for your troubles.
      Try another FTP server - I recommend Filezilla FTP Server, it's opensource. It can solve most of your FTP scanning issues, although you can eventually expect additional trouble when scanning to 64bit OSes.
      Mascan42
      Ibid
      • luis8832
        • Dec 2008
        • 250
        if you go on the konica minolta website, the tech side of it. They actually have documentation on how to set it up step by step.
        • aleksander
          • 378
          I'm using Windows 7. For scan to FTP, you can use Konica Minolta FTP Utility.
          For SMB, you need to share your folder, add the guest account then set the permission level to read/write and set the permission to full control.
          • aleksander
            • 378
            No problem for KM FTP. It really works.
            • Hansoon
              • Sep 2007
              • 3349
              KonicaMinolta FTP-Utility never worked for me but Quick-'n-Easy FTP light does the job very well.
              At the bottom of the page is the download link:
              Quick 'n Easy FTP Server Lite
              Hans
              “ Sent from my Intel 80286 using MS-DOS 2.0
              https://www.copytechnet.com/images/smilies/biggrin.png
              • acusso1234
                Tecnico
                • Dec 2008
                • 250
                Tutorial
                Read here
                MEGAUPLOAD - The leading online storage and file delivery service
                ... In the minute that you're thinking of giving up, think about why you lasted so long ...
                • mrwho
                  Major Asshole!
                  • 4299
                  Well, that was useful. Thanks!
                  Mascan42
                  Ibid
                  • bilyahn
                    • Dec 2006
                    • 1467
                    Thank you as well.
                    Bil
