c353 error code c-2152
  • yannii33
    • 121
    The machines transfer belt is full so I removed it to look at it and when I installed it back in the code keeps showing c2152. I cleared the counter and trouble reset the machine and the code is still there any suggestions thanks
  • kingarthur
    • 1364
    there's a white cog on the rear of the transfer belt...try turning it towards you..if it turns it will do it under it's own power when you start to turn it
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      Description
      C2152 at power up.
      Solution
      PROBABLE CAUSES:
      1. Detecting Plate not positioned properly.
      Shape of the detecting plate has been modified. Install the modified Detecting Plate (p/n A02E 5033 01). Please refer to the attached procedure for
      instructions on how to install the modified bracket.
      Note :The following are the serial number cut-inswith themodified Detecting Plate installed:
      bizhub C353 - A02E010005899 and onward
      bizhub C203 - A02E012005777 and onward
      bizhub C253 - A02E011005566 and onward
      bizhub C353P - A02E013000060 and onward
      magicolor 8650 - no cut-in available
      2. Transfer Belt Retraction Sensor (PS31) mounting bracket (p/n A02E 1121 00) is fixed with a screw and it can be tilted while assembling. If the bracket is
      tilted, the sensor cannot detect the Transfer Belt position properly. In order to avoid tilting the bracket, the shape of the bracket has been changed.The shape of the sensor actuator has also been changed because the actuator could touch the other parts.
      PARTS
      A02E 1121 00 -current Bracket
      A02E 1121 11 - modified Bracket
      A02E 1122 01 - current Actuator
      A02E 1122 12 - modified Actuator
      Notes :
      a.When at the machine, please check the condition of Sensor Bracket and change the Sensor Bracket and Actuator if necessary.
      b. Please refer to details in attachedBulletin Number 6252 (applies tobizhub C203/C253/C353).
      3. Somepacking material was not removed froma new Transfer belt before installation. Ensure that allpacking material has been removed before the Transfer belt is installed.
      4. Failure of the Transfer Belt Retraction clutch (CL7).
      Check for wiring being pinched from bypass door and replace the failed parts.
      PARTS
      CL7 (p/n A02E M200 00)
      bizhub C353 Drive Wiring/1(p/n A02E N10F 02)
      bizhub C253 Drive Wiring/2 (p/n A02E N117 02)
      bizhub C203 Drive Wiring/3 (p/n A02E N10Y 02)
      bizhub C353P Drive Wiring/4 (p/n A02E N11A 00)
      magicolor 8650 Drive Wiring/6 (p/n A02E N11C 00)
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • White Arrow
        We had this error few times, resolved it this way: wiped contacts on machine's inside wall, on left side of transfer belt, and reinstalled the belt.
        • habik
          • 2013
          Take the WHITE plastic bracket (slider actuator whatever) from the transfer belt, remove it and put a mylar strip under that white slider (bracket) if you haven't got a new part as Stirton suggesting. Then assemble and put the belt back.
          Also make sure you have not got "accidentaly" any longer screws for transfer belt on the far side as it will block the drive mechanism , the clearence there is litterally 2-3 mm. It happened to me when I had the fuser out as well and accidentally mixed the screws.
          Let us know . Good luck
          Firmwares HERE
          • jerdanmogley
            Re: c353 error code c-2152
            Nie post. Thanks for all the info.
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              Ha, Ha, my service manager just spent 2 days getting his ass kicked by a C203 with that same code. He could have used that info.
              • AjitN
                • Mar 2009
                • 287
                TRansfer Belt Assy is not seated ptoperly, Try to take out few times and check the machine, Stop the machine by opening front cover OR by opening side cover immediately after stabilization starts after warm up of machine.
                THIS SHOULD RESOLEVE THE POROBLEM
                AJIT
