J31-02 and J21-02
  • elfara
    • Aug 2025
    [Jamming] J31-02 and J21-02
    I have BizHub 600 with problems, J31-02 and J21-02 codes with paper stopping under drum. Can help me?
  • KM_Service
    • Feb 2011
    • 13
    looks like two separate issues, for jam under the drum check the trans/sep corona wires (clean / replace)
    what volume?
    Don't expect the unexpected...............It ruins the surprise !!!!
    • SmellsHot
      Head Tech
      • 512
      Adjust separation voltage if problem continues after cleaning.....
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • 32years
        • Oct 2010
        • 11
        Does problem only happen when running 2sided? If so side 2 is not separating from the drum properly. (You can look in and see the difference between side 1 separation and side 2) New transfer/separation wires might be all you need. Otherwise the transfer/separation current can be altered in service mode paper settings.
