C351 - C2431 Error Code
  • dadams8355
    How can I get around a C2431 error code until we receive our new transfer belt.
  • random
    open and close the front door
    • dadams8355
      Tried that. It keeps coming back. We had to replace the fuse on the transfer belt.
      • random
        Do you mean 2431 or 2451, if it is the later the fuse isn't going to do squat to help you. If this has just happened since your replaced the fuse (assume 2451) then pull the belt and put it back in again. Or pull the belt out and turn the cam on the back and make sure it turns freely. open and shut front door.
        • D Colour
          • Oct 2008
          • 213
          We have a machine giving error code C2451. The machine was asking for a new transfer unit so we replaced the fuse to reset the count and C2451 appeared.
          Is there something else you have to do when replacing the fuse to reset the count?
          Everything that has a beginning, has an end.....
          • Stirton.M
            All things Konica Minolta
            • Oct 2009
            • 1804
            Check your fuse type you used in the belt
            It should be 1/16th amp, or at most 1/8th amp.
            This fuse needs to blow to reset the count.
            "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
            ---Groucho Marx
            Please do not PM me for questions related to Konica Minolta hardware.
            I will not answer requests or questions there.
            Please ask in the KM forum for the benefit of others to see the question and give their input.
            • kingarthur
              • 1364
              When replacing the fuse you may have to get a small flat bladed screwdriver behind the 2 metal contacts where the fuse is, they need to be bent out a little so they make proper contact
