image problem
  • jokacross
    • 110
    image problem
    Hello I have a c450. And here it is the problem
    I made the Image stabilization+Initialize and the first print become like this:
    initialize+image stabilization.pdf
    After 16 prints looks like this:
    after 16 prints.pdf
    Then I made the gradations adjustments the 3 of them and the first print become like this:
    gradation adjust first copy.pdf
    and after 16 prints looks like this:
    after 16 copies gradation adju.pdf
    The original doc is this:
    capa c mar�o pvz.pdf
    What is this?
    One mor thing in the gradation adjust the Conv. Value I cant never get the Right values! In the tree of them
  • minimerlin
    • 851
    Is this the same fault from a week ago? Are the image units chipped? Is the toner OEM? Has the optics been cleaned? You need to do toner add before you do reset and stabilization followed by the grad adjustment. Make sure that the image that is printed (for the adjustment scan) is of good quality or you are wasting your time! When you have got the settings witin the specs switch off the unit and power up again. Do a test printout from the user mode. If your copy/print quality goes bad after a few copies I suspect a stabilizer problem or old IUs.
    Please do not PM me without asking first.
    • jokacross
      • 110
      ok I gona try that and I tell something thanks!
      • Zeldaman
        • Mar 2011
        • 946
