2001-1201 jam codes
  • kjsoll1974
    • Aug 2025
    [Jamming] 2001-1201 jam codes
    I'm getting intermittent jamming on a bizhub 352 with these jam codes the feed tires in this machine were just replaced 2 days ago and they are getting the same jams. any ideas take up and feed and ranspport sensors all work in service mode can see no physical blockages..any ideas?
  • crm.84
    • Mar 2009
    • 15
    When the pf rollers were replaced, were the 1-way clutches replaced? See page 38(2nd cassette paper take-up section) call out #10 in the C352 parts manual. There is a new clutch part# A00J563500 that works better. Clean the shafts w/alcohol and scotchbrite them as necessary. If these clutches slip you get no feed.
