Bizhub 250
  • ronald2020
    • May 2009
    • 31
    Bizhub 250
    Hi u all,
    need help with a bizhub250. I work on Ricoh machine's but have come across this 250 it's displaying the following:
    !*! Abort !*!
    code =0x00900000
    tsk name =tRT16000
    tskid =0x00003e80
    SP =0x8962bd30
    ra =0x812243d8
    build_2591b.060719
    I've replaced the fuser unit, drum unit, development unit i changed these cause they needed replacement & swapped the main board when it was showing the above msg i do not have any technical manuals on km's by the way working on it cause everyone else in our little town has failed to get it right. Your assistance would be greatly appreciated
  • konikilla
    • Nov 2008
    • 43
    I haven't seen this code and cant find it, but it's probably a
    Failed MFBS and/or MEMS.
    First upgrade the firmware to the latest version.
    Then check if DHCP is being used when
    the machine is set to manual IP addressing.
    Lastly clean the contacts of the memory sticks.
    Other than that you are looking at new memory
    or a new MFBS board.
    • Zesti
      • Jun 2009
      • 308
      G3 device control system failure 0x00900000 to 0x009fffff
      MFBS Board, FAX Board, Memory Board*
      Try removing fax board.
      • ronald2020
        • May 2009
        • 31
        Thanx guys managed to get it going now working like a charm now fault was the fax board
        • aleksander
          • 378
          Originally posted by ronald2020
          Hi u all,
          !*! Abort !*!
          code =0x00900000
          tsk name =tRT16000
          tskid =0x00003e80
          SP =0x8962bd30
          ra =0x812243d8
          build_2591b.060719
          Try to replace your MFBS.
          • aleksander
            • 378
            Hi u all,
            !*! Abort !*!
            code =0x00900000
            tsk name =tRT16000
            tskid =0x00003e80
            SP =0x8962bd30
            ra =0x812243d8
            build_2591b.060719
            • Hansoon
              • Sep 2007
              • 3383
              Pssst....... Hey Aleksander:
              Hans
              • aleksander
                • 378
                sorry...lol
                thanks Hans
                • suso73os
                  • 38
                  I had a similar problem and I solve it resetting fax parameters.
                  • fishleg
                    • Mar 2009
                    • 426
                    I hate these machines what a load of turd. Not sure what's worse the crazy error codes you get 10 seconds to write down or that bloody ne nor noise....
                    • Hansoon
                      • Sep 2007
                      • 3383
                      Hans
                      • ddude
                        General Troublemaker
                        • 473
                        HA!
                        Only from the (file corrupted) minds of MINOLTA.....
                        2000 mockingbirds = 2 kilomockingbirds
