HELP! C352 locks up when pressing "Scan" button
  • Copierdave
    I went out to a C352 today that can Print, Copy and Fax. You can even "save in a user box" from the "Copy" mode and retreive a document from the "box" function. But when you push the "Scan" button, the control panel becomes unresponsive. It does not respond to any input from any of the keys or touch display. The only way to get it to unfreeze the machine is to turn off/on the main power switch.
    Any ideas?
  • Bizhub
    • 147
    Hi Dave
    The first thing I would recommend is to upgrade the firmware.
    Let us know how you get on
    Regards
    Bizhub
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      The problem you desribe is listed on KM SSD site they say its a hard drive problem.
      Now into Ip TV KODI Boxes
      • Copierdave
        Thamks for the input pepper38_cnd and Bizhub.
        It turned out to be a HDD issue. Reformatting the HDD fix it. If it happens again, I'll replace the HDD.
        pepper38_cnd, If you are not all ready a member of the Trouble Shooting Forum - Login forum, I would like to invite you. If you have any problems setting ip an account, please email me at copierdave@gmail.com
        • pepper38_cnd
          • Aug 2005
          • 1075
          Thanks for the invite Dave, I'll check it out.
