Minolta Bizhub 162
  • AHMED
    Minolta Bizhub 162
    PLEASE What Minning ERROR CODE : F032
  • fidelio
    • 18
    You have a problem with bias votage. First of all go to service code : status/counter/stop/0/0/stop/0/1. find AUTO ATDC. and green "go". Should help. if don't open the unit and clean all contact.
    • AHMED
      think you very mutch it's good...
      • AHMED
        the machine is very noise
        • fidelio
          • 18
          all of these mashine are very noise.
          • Rudi
            • Jun 2007
            • 251
            if your noise is anything like gears jumping then you will have to strip the imaging unit and clean out all the toner recycling pipes you will also find that sometimes the toner actually starts building up in the dev tank where the recycling pipe fits over so remember to clean out that part too, that is probably also why you are getting the error code.
            • AHMED
              Minolta Bizhub 162
              Thanks A Lot
              • minolta35
                Trusted tech
                • Apr 2005
                • 87
                you must remove the developer unit
                might be end of its mixer was broken.And you can change a new one..
                • juan carlos guardado
                  will be cof32, is developer
                  • AHMED
                    Konika 3340
                    Please Code Dev Of Copieur Konika 3340
                    Thanks For All My Freinds (juan........
                    • tikis
                      where me to write service code?
                      • ni311
                        • May 2008
                        • 658
                        just push the buttons in the order fidelio told you. After this, you should see on screen 'Service Mode', go to Functions -> ATDC Autoadjust.
                        Konica Minolta Error Codes - Explanations and Solutions
                        • tikis
                          need to conect with computer or not??? i'am not find where to write this code
                          • deep
                            • Jun 2008
                            • 208
                            No computer connection is needed. Just press the keys on the control panel of the copier.
                            Kenny
