Konica Minolta Di7210 - E34-01
  • burncrauder
    • Jun 2010
    • 12
    [Error Code] Konica Minolta Di7210 - E34-01
  • BIG PAPA
    Da Boss
    • 234
    You did reset the memory switch? 3-1 to 0. If not you replaced alot u didnt have to.
    sigpic
    • burncrauder
      • Jun 2010
      • 12
      I did reseted the DIPSW 03-1 from 1 to 0. But when I turn the machine off and on again i get the same error.
      • BIG PAPA
        Da Boss
        • 234
        Sorry no offense had to ask. The only parts I have had to replace for fuser codes are the temp sensors, thermostat, or lamps, which you have done them all. Does the fuser heat up? When replacing the temp sensors(I think there are jigs but who cares) are the sensors making contact with the roller?
        sigpic
        • burncrauder
          • Jun 2010
          • 12
          That's the problem the fuser isn't heating. When I turn on the machine the lamp's doesn't even turn on and I get the error code.
          I replaced the thermistor using the jigs, the TH1 isn't in contacting the roller and the TH2 is.
          • rocky246
            • Feb 2007
            • 91
            Check the plug on the fuser and the plug in the back of the machine for broken blades.
            • remati
              • 149
              -Maybe a bad contact ,between the fuse unit ,and the machine...
              -Look the power connector-could be calcined...
              • burncrauder
                • Jun 2010
                • 12
                Re: Konica Minolta Di7210 - E34-01
                Hello every body. I finally fixed that error. The Main Bord had a short circuit with the diode that controls temperature. I found this becouse i sent the board to a eletronic tecnitian that's a friend of mine.
                Thanks for replying.
