I have to reinstall the system software on a PI5500 controller...
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    #16
    Hey Joshua
    I will do what I can to help, just a little more info. What version are you at? If your system is still working do you know that an upgrade will benefit you (if it aint broke don't fix it)? There are a ton of patches, is it possible all you need is a patch?
    As for the scanning, I'll be honest I am a Konica Tech and not overly familiar with the Minolta products. But I will do a little research, if that product supports scan to PC SMB ( Scan directly to folder on pc or server) that is the way I would recommend scanning.
    Some one else has requested the patches so I will email you a YouSendit link to the patches as well, link will only be good for 5 days so download them as soon as you get it. Make sure you read thru all the read me files before applying any patch.
    Let me know how you made out.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • jgspeer
      #17
      Current Version 1.1
      Hi! Thank you for responding. The current version is 1.1. I've seen images of the interface for the fiery that has the 2.0 version and it has a scanner tab, whereas mine does not. Nor does it say anything about scanning. Under WebTools I can access scanning functions but it is very limited.
      Thanks!
      Josh
      • pepper38_cnd
        • Aug 2005
        • 1075
        #18
        Josh
        Check your PM's
        • costi010380
          #19
          Hi, I'm a junior service tech and I have a problem with 2 Pi5500. One of them has the HD full and i couldn't find a way to clear the stored jobs. The other one has the System ver. 1.1 and i need the 2.0 ver. in order to scan and manage documents on my DI 450.
          Please if anyone can help me!
          • poizzon
            • Sep 2008
            • 3
            #20
            may somebody can help - crashed HDD, try'ing to restore but didn't have any cd's..
            hardware is :
            Fiery Pi550
            Model mxi-01
            Part number 45025807
            • Andrusa
              #21
              Originally posted by pepper38_cnd
              The only thing I see on the KM web site is System Code Version 2.0 released March 23, 2005 The file is an ISO file 201.7M
              If that is what you think you need let me know and we will figure out a way of getting it to you.
              Please, I need that iso too, how can I get it ?
              I have pi5500 mxi-01
              • jeffee1
                #22
                Ditto
                I am transferring the file to your FTP
                the trusty pi5500 crashed on us. Think it's the HDD, I'd like to try reloading the OS before we spend any $$ on it. Can you help?
                thanks in advance!
                • criscasmo
                  #23
                  repair manual
                  Hi, I have a fiery server model MXI.01 too, did you have any repair manual I think that the problem is the HDD because the sys do not start and the hdd led do not link.
                  The idea is remplace the HDD and install the OS
                  • fldevs
                    #24
                    I need to update/reinstall the software for our pi5500 as well...any help would be greatly appreciated!
                    • NG_tech
                      #25
                      :: PI 5500 System Software needed ::
                      My pi5500 hdd crashed down, so I need system software files.
                      Does any body knows if a bigger disk than 10Gb it is supported by the pi5500?
                      Thanks in advance.
                      • Hansoon
                        • Sep 2007
                        • 3389
                        #26
                        Thanks in advance.
                        We have them around with 20 and 30GB disks, no problem.
                        Hans
                        • NG_tech
                          #27
                          Hans,
                          Thanks for the info.
                          NG_tech
                          • Lorian
                            #28
                            PI5500 System Software
                            I also need this software. Kindly please send me link
                            THanks,
                            Lorian
                            • FlyHi
                              • 5
                              #29
                              I have the same problem, please help. Тhanks in advance!
                              • NG_tech
                                #30
                                pi5500
                                Chech your PMs
