error code 0094 on a Konica Minolta C35
  • copier tech
    • 8200
    #31
    Re: error code 0094 on a Konica Minolta C35
    Originally posted by Qball
    I just had two of these shit bags throw this code on me. Same account, same day. What an utter piece of mother fucking garbage. Both of these assholes need a right door assembly. One of the posts that a gear is mounted on was broken. ON BOTH UNITS!!!!! What a great indoctrination to the C35. And thank you service manual for not having a procedure for replacing the right door. Nothing like building the customer's confidence like looking like a monkey fucking a football while fumbling through this. C35, go fuck yourself.
    These C35/25's have been out for years, they are made out of 99% plastic, the only parts we replace is the image units & fuser if anything else fails we replaced the printer.
    Updating to the latest firmware allows you to turn of the "replace iU" message the only good thing about the C35!
    • jbilyeu
      #32
      I have been doing research to see if we can find a solution to Error 0094 with Konica Bizhub C35. The message boards say that there is a foam pad that gets sticky in the right door assembly that is meant to dampen the sound from the 2ndRemember that two gears are timed, on the rear side of the right door. Line up the arrows with the notches. The guide containing the IDC sensor can be removed by pulling it up out of its slots, first the toners, Image units, WTB, and fuser must be removed. The solenoid is behind the gears on the rear of the door, no need to remove the guide to remove pad. Pad is small and black, about 1/2 mil thick, about 2x5 mils in size. I removed pad with a knife, then removed residue with a Q-tip dipped in alcohol. Code became more frequent over time, as the pad became more and more sticky.
      I am Konica Minolta tech and I removed these pads on at least 10 different c35 machines in last 5 years without ever have to go back to any of those accounts again.
      I have just seen this fault for myself, my fix was the solenoid pad, for the record it's not on the solenoid but on the frame, not easy to see, I used a flashlight. Pressing the solenoid by hand there was a delay due to the pad going sticky, after I removed the pad the arm returned back instantly.
      • evels
        #33
        Pedazo de FOAM para estabilizar el solenoide 1.jpgPedazo de FOAM para estabilizar el solenoide 2.jpg
        Originally posted by Mr. Joshua
        Make sure the second transfer release solenoid isn't hanging up due to the pad that's there to minimize noise. See the attached pic. This pad had gotten sticky enough that it was delaying the action of the solenoid. Took a lot of service calls to figure this out!
