Develop ineo+253 alias KM c253 don't start
  • giuseppect
    • Jun 2025
    I have a problem with this copier
    After a blackout it don't boot anymore
    I only got an hour glass screen
    I've just unplugged all the boards and unplugged the SODIMM without success
    In the main board there is a fix red led
    What could be?
    Sorry for my english that it's not perfect
    Thank'you for cooperation
  • rprem
    • 49
    nv ram problem reinstall it problem will be solved
    Head Lines Are Made When Dead Lines Are Met
    • giuseppect
      How can I do?
      Are you talking about the NVRAM reset software?
      • jamesmutz
        • Apr 2011
        • 6
        Couple things to try. First just try updating the firmware. If that doesn't work, try the special NVRAM reset firmware. If still no go you'll have to replace the NVRAM board.
        • boanda
          • Feb 2011
          • 79
          Just use special firmware for "hourglass" problem
          • giuseppect
            Thanks to all
            Problem solved using JIG Firmware and NVRAM recovery card
            See you
            Giuseppe
            • karl
              • 2
              Re: Develop ineo+253 alias KM c253 don't start - I have the same problem
              I know this is an old thread, but I have the same issue on my (home based) Ineo+253. It happened after the machine turned on/off a few times due to a loose power cable.
              I had someone in to look at the machine today, he informed me that he thought the main board was faulty and I would be better off getting a new machine.
              No attempt to re-flash or reset NVRAM, just a few power on/offs and thanks for the call out charge I know, everyone needs to pay the bills!
              Is the NVRAM reset firmware still available for this machine? I have the service manual, I have CF cards of the correct size (256MB).
              I just need someone in the Cambridge area who has access to the firmware and knows how to installed it / reset the NVRAM. I am not looking for
              a freebie, I just cannot find anyone who appears to know about this machine.
              PM me if you can help / know of anyone.
              I really don't want to skip an otherwise perfectly good machine.
              Karl
