km c450 no color
  • bizhub1
    • Sep 2008
    • 230
    #16
    sorry I mis spoke, you have to go in service mode and check the retraction sensor, not the motor
    • copytechman
      • Nov 2008
      • 926
      #17
      According to the book, if the retraction/engagement mechanism wasn't moving properly you'd be getting C2152 codes all over the place. Its the code that box throws when the retraction sensor doesnt get triggered in a timely manner. Not to say something else isn't broken tho and allowing the "mechanism" and sensor to work properly but no actual engagement of the 3 colour 1st transfer rollers. (assumes alot!)
      Regards! A
      Edit: also running say 20 black copies then 20 full colour copies (not auto colour) and back and forth like that will force the machine to engage/retract colour transfer rollers. If you don't get any c2152 codes after doing that a bunch of times then IMHO its pretty safe to say the retraction sensor (and associated mechanisms) are indeed working and you MAY have a different issue.
      • chriscctx
        • Mar 2010
        • 37
        #18
        I'm thinking a motor is out or not running. All image units have been swapped out. 3 different transfer belts have been put in. All with the same issue of not printing color.
        • copytechman
          • Nov 2008
          • 926
          #19
          Again according to the book there are c-codes for drum and dev drive motors on that model, however a quick inspection of the book leaves me to wonder if you have an led head failure of some sort since I didnt on quick inspection find any sort of failure codes for them. Possibly a faulty icp or something that controls the 3 colour led heads? I don't know for sure but if the machines only throwing P-codes and no C-codes then I'd maybe start there somehow.
          Regards!
          A.
          • bizhub1
            • Sep 2008
            • 230
            #20
            Regards!
            A.
            Yes I agree totally with the codes, I would make sure all the drive linkages to the belt unit are fine also.
