BizHub 250
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    BizHub 250
    I bought the machine from wholesaler. machine was taken off base and moved. Was unable to test so don't know if this was a problem before. Has 3 tray configuration. Tray 1 & 2 read 5.5 x 8.5 and will not change. Tray 3 shows correct paper size.No paper stuck behind trays blocking sensors. Everything looks fine with trays and all switches & sensors on inside frame. Any ideas appreciated
    Thanks in advance
  • mo0651
    • 1054
    sensor arms could have been bent. I think you can swap the sensor banks in that unit. worth a shot.
    • Hansoon
      • Sep 2007
      • 3391
      Often the flimsy plate where the sensors are mounted gets bend to the rear of the machine. This happens especially after transporting of the upper unit.
      Just pull/bend the plate back where it should belong.
      Hans
