C250 no light on display. But machine works fine
  • fummbles
    • Dec 2010
    • 22
    [Electrical] C250 no light on display. But machine works fine
    Ive tried the control panel and the wiring. Ive also checked all the connectors.
    You can just make out the display, its as though the bulb has gone.
    Thanks in advance
  • LOURD
    have you tried to replace the control panel? or tried to repair it ?....
    • fummbles
      • Dec 2010
      • 22
      Yes and the wiring, disconnected and reconnected all connectors on PWB's... Still no joy..
      • mrwho
        Major Asshole!
        • 4299
        Either the display is gone (the backlight is fried) or the inverter board is at fault.
        Mascan42
        Ibid
        • JustManuals
          • Jan 2006
          • 9838
          Just Manuals | The Internet's largest selection of manuals | Instant Downloads
          Paul@justmanuals.com
          • fummbles
            • Dec 2010
            • 22
            Ive tried another Control Panel from another machine that was working.. The Invertor board was on the control panel.
            • mrwho
              Major Asshole!
              • 4299
              So it was a failed inverter board. Nice to know you solved it.
              Cheers!
              Mascan42
              Ibid
              • fummbles
                • Dec 2010
                • 22
                No its not fixed, just stating that the invertor was on the control panel that i swoppped.
                Sorry for the mix up...
                • mrwho
                  Major Asshole!
                  • 4299
                  So you tried another panel that you know it's working and the problem persists with the new panel, is that what you meant?
                  If that's the case, then it's an odd one for me.
                  Mascan42
                  Ibid
                  • acusso1234
                    Tecnico
                    • Dec 2008
                    • 250
                    A minute to write this on one of yours to give a look at the scanner cable down silver connection..
                    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
                    • Leandro Bourne
                      Re: C250 no light on display. But machine works fine
                      does anyone solve the problem?
                      i have two machines with the same problem...
                      back ligh not working but the machine is fine
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        PWB-M, try a new one, and dont forget to swap over the removable IC to the new one. (The right way around!)
                        • copytechman
                          • Nov 2008
                          • 969
                          Had one of these on a c352... blown icp on the scanner board if i recall right..
                          Not sure if same as a c250 tho.
                          Regards!
                          A.
                          • hazartilirot
                            • Aug 2016
                            • 10
                            Can I ask you what IC stands for?
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              integrated circuit.
                              i'm referring to the socketed 8 pin dip serial eeprom on the PWB-M board, it is to remain with its original machine.
