Scratch in image Bizhub C5501
  • bpifer15
    Jr Tech
    • Mar 2011
    • 36
    I am getting 2 scratchs going through my image only on the black. It started as only 1 scratch and is not 2. I checked guides and do not see anything. Any suggestions on where to look?
  • ineo+6501
    • Mar 2010
    • 262
    Dust on the black laser, clean the glass
    • bpifer15
      Jr Tech
      • Mar 2011
      • 36
      Great I will try that. Thanks
      • bpifer15
        Jr Tech
        • Mar 2011
        • 36
        Only one line went away. I cleaned the glass twice, the one line went away right after the first cleaning. The second line still remains. Any other place to look?
        • RRodgers
          • Jun 2009
          • 1947
          [ATTACH=CONFIG]9938[/ATTACH]
          Under the black dev unit.
          • JustManuals
            • Jan 2006
            • 9838
            Just Manuals | The Internet's largest selection of manuals | Instant Downloads
            Paul@justmanuals.com
            • bpifer15
              Jr Tech
              • Mar 2011
              • 36
              Cleaned out under the black developer and still have the line. Anywhere else or is it just a matter of cleaning it better??? Thanks for the help!
              • RRodgers
                • Jun 2009
                • 1947
                Its blockage in the doc blade gap then, take off the bottom cover and use a bisiness card to clean it out.
                • bpifer15
                  Jr Tech
                  • Mar 2011
                  • 36
                  Sorry, not sure if I know what you mean by doc blade gap?
                  • minimerlin
                    • 851
                    Possibly a hair is hanging from the grid?
                    Please do not PM me without asking first.
                    • ineo+6501
                      • Mar 2010
                      • 262
                      The doc blade is the metal plate which controls how much developer attaches to the magnetic roller in the developer unit. A business card carefully dragged through the gap between this blade and mag roller can remove any build up of grit or whatever which may be stopping the developer getting through in that spot.
                      • akiyimba
                        change the charger
                        dear sir
                        some times may caused by the charger try changing it and see i experienced this on asmaller machine
                        • Cantechman
                          • Nov 2008
                          • 227
                          I had a similar line on that model one time. It was a piece of lint under the developer unit.(interfering with the laser path to the drum) You should remove the black unit and use a good cloth wipe it up real good there. It can be a very small piece of debris that can cause interference. If that doesn't work, look at the dev unit to make sure it has a uniform coating on it. Next I would switch the corona unit to see if the problem moves.
                          • bpifer15
                            Jr Tech
                            • Mar 2011
                            • 36
                            Thanks for the description. I will give that a shot
                            • Herrmann
                              • Jan 2006
                              • 792
                              As cantechman said, it can be a very small piece of dust causing this lines. The 5501/6501 are great boxes but they are extremly vulnerable for dust in the Laser Path. Even though your Problem only is in the BK Area, you should remove all developing units, clean them from toner as the duct where they sit in also. If this Problem occurs often, you should think about the little modification i made to get rid of this Problem
                              http://www.copytechnet.com/forums/ko...ht=#post207890
                              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
