Have a Bizhub 420 that jams at the reg.roller with the rear edge of the paper scrunched up after the loop roller as if rego roller has not started and the loop roller has run on.
Not sure which clutch is at fault or if its the temp.stop sensor?
From what I have read on web sites both of these clutches play up.
I am about to order both clutches but am curious which one you think it may be.
It looks sraightforward removing this assembly though I havnt removed one before so any advice on removal of the transport unit assy would be great.
Bushy
Bushy
