350 code c2557
  • maj143
    • 55
    350 code c2557
    this code is show when i make copy and jam on before heater ,
    the copier show that changing drum uni ,
    if i change only the drum well work the copier or i have to change dev alsoo,
    and i want to know if there are any programing to it .
  • Darren King
    copiertech
    • 652
    You have to change both drum and dev at the same time, and then run an F8. Don't forget to clear counter as well.
    Good luck
    Darren
    • mitchl
      • Apr 2007
      • 500
      C2557 is a ATDC sensor failure if my memory serves me right. Replace the Sensor (UN2) I have seen where the code doesnt go away after replacement and the only way I could get rid of the code is by resetting the DV count In counter mode under "special parts counter" Have fun!
      • higherlevel
        • Aug 2006
        • 30
        C2557
        This Code is again the Toner Density Sensor being to low, but as stated above...Dev and Drum need changed....when it says this...of course the F8 developer mode calibrates the developer / toner ratio, but also resets the Developer count, the drum count can be reset without changing the drum, but not recommended...so change drum and developer together.......So if the PM is 100k or more, suspect Drum / dev. if not, read below
        If less than 100k pm , I have also had a bad Toner sensor in the Developer unit...and have changed it....
        Usually a dev / toner ratio of less than 5% triggers a c2557...but a value in another menu can be changed to bring it to a higher level if needed...
        • maj143
          • 55
          thanks for your help ...... iwell try it and let you know
