Bizhub C250 No Cyan
  • mrfuser
    • 1617
    Bizhub C250 No Cyan
    Machine works fine, just does not produce ANY CYAN at all! No errors either. Very strange.
    Any ideas?
    Kelly
  • JSC
    Gimp
    • Dec 2006
    • 618
    Check the cyan transfer roller in the transfer belt has not "popped" out of it's housing, next I would swap the cyan laser with another colour.
    Good luck
    The gene pool could use a little chlorine.
    • remati
      • 149
      certenly a laser problem I agree
      -Did you try the internal test prints in service mode..... Gradation pattern... if you have all colours ?
      • TugmysterUK
        • Mar 2008
        • 13
        laser is controlled by MFP ive had a couple giving me wierd copy quality issues as in no cyan , magenta etc .. could be the answer ( worse case )
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          Another possibility is the HV-Board. Had a machine where the contacts are not in the correct position.
          Greetings...
          • sajja
            bizhub c252
            Hi i have a c252 with error cord c2653 even after replacing the yellow and black imaging unit, it still brings back the same error.
            what could be the problem
            Help
            Sajja Wilson
            • mrwho
              Major Asshole!
              • 4299
              Any ideas?
              Kelly
              We had a similar problem some years ago where the laser was not pointed at the drum because the base where it sat was bent. If you replace the laser with a known working one, that's one thing to check.
              Mascan42
              Ibid
              • 1FRY1
                • 51
                I'd go with the HV , no charge strips the toner and dev out
                turn the mag roller is there any dev and toner on it
                • sprawl
                  • Jul 2009
                  • 27
                  just front door open /close? It reset that code.
                  [Completed] Outaward, [Completed sertifications] C652,C552,C360,C280,C220,C35,C353,C203,C20p,C25
