Reset the counter on imaging unit C450
  • gateway.vly@gmail.com
    • Dec 2007
    • 53
    #16
    ok plz give thair name and number
      • Dec 2007
      • 53
      #17
      helo
      can u help me to upgrade firmware on bizhub c250
      i cant make compactflash card
      plz tell me how it make
      • bosnjo
        #18
        Originally posted by chipreset
        Yes, we can reset your bizhub chips, $12.00 ea.
        I need your info, phone number or address ,
        might need magenta IU reset, bizhub c450
        please respond
        • Techace
          • 35
          #19
          thanks my friend. believe me! it works. and thanks again for saving my dirhams.
          • bosnjo
            #20
            those chips really work
            I have ordered three of them and they work
            15 dollar a piece
            ebay is the law!!!
            • Mikehub280
              #21
              iu chips
              $15 a chip? I have a car load full of them for all my ranges. I should sell them for $7 and undercut the big guys muhahaha
              • mailderrick
                • Mar 2010
                • 131
                #22
                Originally posted by mitchl
                Yo Gateway understand this!................. There is no mode in the machine that will reset the IU count........PERIOD. You either need to install a new IU or the NVRAM chip must be cleared and reloaded, ie: RESET! Buy a re setter or reset chips(check Ebay) or a new IU, take your pick!
                Yo mitchl you are only half correct. There is not mode tha twill reset the IU count yes! BUT !!!! you can change IU life from stop to continue
                • hossam
                  • Aug 2010
                  • 70
                  #23
                  Originally posted by halia_merah
                  try this one friends...but i dont know it works or not.but for the machine C 250/252 it's work.but the display to change I.U still there.
                  "Utility - Detail - Stop - 0 - 0 - Stop - 0 - 1.When it's display service mode ,enter Stop - 0 - Clear.Highlight Imaging unit counter, change stop to no stop."
                  the Imaging Unit still can be use untill the print get worse.But the display to change Imaging Unit still appeared.
                  i did it on bizhub c450 and it's working thx
                  • krish
                    • 16
                    #24
                    hi, you will get chip reset unit. It will cost you 450/500 euros. With that you can reset the chipes by loading with the software dump provided by the supplier. Or you will get the programmed chips readily available. When you are ordering these chips, you must tell them whether your m/c is us m/c or uk m/c or german mahine because the software in the chips are different for above countries.
                    • mailderrick
                      • Mar 2010
                      • 131
                      #25
                      you should...and i will be there to buy some!
                      • mailderrick
                        • Mar 2010
                        • 131
                        #26
                        IU life continue : this is the best way to do it. by rechipping you are taking risks that putting a new voltage to an old iu ..could cause color mismtch,grainy prints,and possibly even overtoning
                        • krish
                          • 16
                          #27
                          I have been using the same for 2 cycles and did not have any problem with the color matching. YOu can continue the IU units life by normal way (as already mentioned by other members) but if you are using the FIERY, it will not work. i.e. fiery will ask you to replace the imaging units. IF you do not have A FIERY, it will work.
