bizhob c203 firmware
  • acsolutions
    • Jun 2010
    • 519
    I was wondering is there a way to upgrade a c203 with a cf card from another machine? I need both machines to work.
  • RRodgers
    • Jun 2009
    • 1947
    Hmmm... I think I remember there was a backup procedure with a CF, but that would be to only one machine and I don't think it would work on the other.
    • acsolutions
      • Jun 2010
      • 519
      can you copy the info from one card to another?
      • acsolutions
        • Jun 2010
        • 519
        if I was to remove a card from machine ( working machine) and place it in a none working to see if it works, could it corrept the card from the good machine.
        • boanda
          • Feb 2011
          • 79
          Make a backup from goodone,just to be sure, and try
          • copytechman
            • Nov 2008
            • 943
            Ummm last time I checked, that model doesn't run off of a compact flash card. Firmware updates / nvram recovery etc yes.. But run? Not to my recollection... I know the 501 series does, and not as yet sure about the c220 series or 223 series. But not the c203 series unless its hidden where i've never seen it!
            Regards!
            A.
            • boanda
              • Feb 2011
              • 79
              I understand that he just want to use CF card to update firmware which have firmware for other model.
              Of course the c203/253/353 series not run from CF, just upgrade
