How to disable the saddle stitch / booklet maker on bizhub c-352
  • beatbrother
    • Feb 2011
    • 24
    #16
    Hey mmru4real.
    The finisher and copier in question is a Bizhub c352
    but we cant get the booklet maker of the copier even tough is off physically.
    Any help
    • mmru4real
      • Aug 2008
      • 67
      #17
      beat i understand that it is on a KM C352, but it was made by canon and is utilized by xerox, sharp, canon, konica minolta and oki data, these came standard with the saddle stitch and I dont believe you can just remove the saddle stitich and and disable it because they were marketed and sold as a complete saddle stitch finisher.
      • habik
        • 2013
        #18
        that is correct - Saddle stich and crease unit comes as a kit.
        So recap:
        Saddle is out.
        Crease is out.
        ......try and check in which position you have the paper exit trays that gave me a hard time.
        this is in manual
        Note:
        Install the holder for top tray at a level one step lower than
        where it was removed in step 27.
        Firmwares HERE
        • beatbrother
          • Feb 2011
          • 24
          #19
          Hello MMRU4Real
          So we are talking about the finisher from Habik correct?
          the one that Habik posted below.
          That is very interesting, the fact that that all been made by Canon.
          I'm going to try the option given by Habik and see if it works otherwise 4REAL may be correct, those finisher are built in and you can not remove them.
          • beatbrother
            • Feb 2011
            • 24
            #20
            Hello Habik.
            The picture was very helpful!!
            I put the tray back to the original position but unfortunately No success :-(
            Could you please send me the instruction how to enable the booklet maker in the service mode??
            ir if it is easier the whole link or PDF where you took that picture.
            I think if it says how to enable it and set it I'm just going to follow the steps backwards.
            Thank you In advance Habik.
            • SmellsHot
              Head Tech
              • 512
              #21
              Hey beatbrother send me an email addy so I can send you the Saddle Stitch Installation manual.
              Everyone has the right to be stupid. Some people just abuse this privelage more than others
              • habik
                • 2013
                #22
                You are not disabling saddle/ crease , it is either installed or not. have you got the manual already or ...I did send you msg yesterday and did not get response from you.
                Firmwares HERE
                • beatbrother
                  • Feb 2011
                  • 24
                  #23
                  Heloo Again Guys !!!
                  I am so sorry for the delay, I was attending a Toshiba seminar...
                  Smellhot: my Email is beatbrother10@hotmail.com
                  Please send me the set up manual for the installation for the finisher / Saddle Stitch Installation manual, it would be very helpful.
                  Habik: I am so sorry for the delay bud, I think I did not receive it. Would you mind to re-send it again??
                  Thank you Guys
                  • a1computer
                    #24
                    Re: How to disable the saddle stitch / booklet maker on bizhub c-352
                    Do anybody know how to diable this finisher from bizhub c-352
                    • kingarthur
                      • 1350
                      #25
                      when you initially install a saddle stitcher, you have to cut off a piece of plastic, which went into a sensor, you may have to re order that complete piece intact....if you look at the installation guide it will tell you what you have to cut...that is what is missing......as far as i can remember...sorry its so vague
                      • beatbrother
                        • Feb 2011
                        • 24
                        #26
                        Hello Guyos
                        I still think that has to be something related to any switch SW or something or may with a loop connector
                        • kingarthur
                          • 1350
                          #27
                          look on page 7...section 34 of the installation manual.....have you replaced the piece that was cut off....you have to remove it to fit the SD....so if you remove the SD...you have to replace it.....
                          • beatbrother
                            • Feb 2011
                            • 24
                            #28
                            Hello King Arthur
                            Can you send me a picture with that info please???
                            I don't have the installation manual
                            Thank you in advance
                            • Tec1
                              • Dec 2011
                              • 48
                              #29
                              did you ever figure out how to get rid of open door signal, when removing the SD-503?
                              I have a customer that wants it removed and having same problem.
                              not finding SD-503 installation guide
                              • Masterchief
                                • Apr 2011
                                • 280
                                #30
                                Why did this thread start of on KM and end up on BIZHUB can we keep it simple please
                                sigpic
