c450 hazards on print
  • jokacross
    • 110
    there are hazards on print. with is that and what can i do? here a scan of on copy I have made. Note that the zone is in a red rectangle. thanks a lot!
    scan.pdf
  • mrwho
    Major Asshole!
    • 4299
    Mascan42
    Ibid
    • mrwho
      Major Asshole!
      • 4299
      Oh, to reply to this post use this link: http://www.copytechnet.com/forums/ne...4471&noquote=1
      Mascan42
      Ibid
      • jokacross
        • 110
        gradation.pdfgradaton2.pdfgradaton3.pdf
        • mrwho
          Major Asshole!
          • 4299
          How's the consumable sheet? Is any consumable near the end of life? (If any IU is chipped or any other consumable reset by fuse or service mode, then the answer should be "yes").
          Try to post in english also - this thread could help someone else in the future!
          Mascan42
          Ibid
            • 23009
            If you enlarge to 400% and examine the side voids toward the center of the page you'll see that the image makes a brief shift, the back. I interpret this to mean one of a couple of possibilities:
            I believe that the paper is shifting in the main-scan direction during secondary transfer.
            There may be too much paper buckle.
            The leading edge may be snagging on something in the paper path near the fuser inlet. (what paper weight?)
            I've seen something similar on Okidata printers, when very heavy paper stock is being printed. When the leading edge reaches the bite of the fixing rollers the paper momentarily hesitates as the fuser tries to advance the paper. This creates a buckle that distorts the image that is still transferring further down the page. Is the artifact always the same distance from the leading edge?
            • mrwho
              Major Asshole!
              • 4299
              Originally posted by mrwho
              PPS: Don't end a thread's title with "Print".
              Anyone else noticed that Aneurysm solved this wee little problem?
              Mascan42
              Ibid
              • jokacross
                • 110
                yes aLWAYS THE SAME distance! Thanks for your reply
                  • 23009
                  I don't want to mislead you. The heavy paper issue was not something that could be compensated for on the printer. The paper was just too heavy.
                  The customer would produce documentation that the paper was 7.4 point (~110# offset, ~60# bond) which was the top limit as far as paper weight goes for that specific machine. All I could do is advise them to use lighter paper.
