I have a copier with this error code,first I changed the developer and run f8 function.C2557 is displayed in the display.What can I do to solve this problem?.People says that I must change drum whit developer at the same time. maybe the toner sensor is bad.How an I check it? When I change the atdc value the problem continues.thanks.
bizhub 350 error code c2557
Tags: altering, atdc sensor, bad, bizhub, bizhub 350, change drum, code, copier, drum, error, indigo, time, toner
Whenever I encounter this error code. Changing the ATDC Sensor Gain to 170 always fixes it. You should find it in service mode under tech rep choice>printer>atdc gain -
Enter here in this forum C2557 in the search box and you will find many threads about this issue.
Hans“ Sent from my Intel 80286 using MS-DOS 2.0“
https://www.copytechnet.com/images/smilies/biggrin.pngComment
This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
Paul@justmanuals.com
It may be too late. The drum and developer should be changed together. If you put a drum in and run F-8 and it still codes, you may have to change the developer again.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
Re: bizhub 350 error code c2557
http://www.copytechnet.com/forums/konica-minolta/55743-konica-minolta-bizbub-200-c2557-code-2.html#post249125
hope it will help with the new developer.Comment
F8 after the show this problem and you need to adjust the ATDC to 185 or 180
I'm sureComment
if someone increase the atdc, what exactly happens actually? will it shorten the life of the developer?Comment
Humble_me84
try to reset the counter first and performed F8. it will work..
goto service mode>counter>special parts counter>press developer>press "C" for clear.Comment
try to change the developing unit+developer..
Then run F8..
If still wont work.Comment
Dev counter doesnt need to be reset on this model but the i/c counter sure as heck does or you will get an C2557 on doing the F8 adjustment. (same spot special parts counter) the dev counter increments by 1 and resets when f8 is run..
Regards!
A.Comment
