bizhub 250 with background
  • mrwho
    Major Asshole!
    • 4299
    [CQ] bizhub 250 with background
    I've got a colleague over the phone asking me for help on this. Everything I could think of he told me has been done:
    - New Drum Unit
    - New Developer
    - New Transfer Roller
    I'm stumped. Could it be the developer unit itself? The interval between the defects doesn't suggest that. Maybe something else?
    Thanks.
    Mascan42
    Ibid
  • SPBE
    • Sep 2010
    • 70
    Yeah, I would replace the dev. unit.
    • mrfixit
      Senior Technician
      • Sep 2007
      • 84
      I agree, try the dev unit. if you roll that copy into a tube lining up the marks I'll bet the circumfrance is the same as the mag roller
      • mo0651
        • 1054
        check all the little copper grounding contacts around the drum and trans roller. see if they are making good contact.
        • Hansoon
          • Sep 2007
          • 3374
          As suggested above, first check the copper contacts. If not than its the developing unit. Likely there is something wrong inside of the mag roller. How many copies made the developing unit until now?
          Hans
          • fixthecopier
            ALIEN OVERLORD
            • 4714
            sounds like its time for new DV collars.
            Bizhub 250/350 eating drums
            • solis557
              • Dec 2010
              • 53
              Re: bizhub 250 with background
              That is a dv unit issue replace it along with new dv
              • mitchl
                • Apr 2007
                • 501
                Or if you have access to another machine toss its IU in and try to get a copy before it throws a ATDC code, which may or maynot happen.
