bizhub c352 error
  • aaahmmm
    • Aug 2009
    • 103
    bizhub c352 error
    Dear all
    I tried to upgrade Firmware for bizhub c352 , using kingstone CF compact flash 4GB and using Firmware Imaging Toolkit 2006.
    I did exactly the procedure in the service manual and every thing was perfect and exactly as in the procedure (each check sums are identical)
    Then after I Insert the compact flash card into the slot and switch on the machine.
    I have the following error
    This is invalid card
    Please make sure the card
  • jrf
    • 142
    I have 3 cf cards exactly the same but only one will work, the others give the same error as yours, so try another card
    • mo0651
      • 1054
      4gb card may be too large. we use only 256mb but they r hard to find.
      • mrfixit
        Senior Technician
        • Sep 2007
        • 84
        I'm a little burnt but I seem to remember only being able to use san disc cards and the smaller the better.
        good luck
