I have a Minolta Di351 with a PI3502 with the NIC that I keep getting a error when trying to print to it. I can go into the DOS cmd, and do a ipconfig, and it recoginizes the ip address. I can also try to do a ping command to it, and it replies back ok. I have the printer configured with the PCL6 drivers. When I look at the print queue it shows the job is there, but just says error and never prints the job. The OS I'm running is windows XPpro. I have no firewalls enabled. Any suggestions, desperate.
Also this Pi3502 has the scan card option installed inside the PI3502, but I get no indication on the status printout sheet. I get a display when I select the scan button on the copier which shows a bunch of empty squares and some indicator tabs like (addr, menu, etc.)along the top of the screen for various selections, but see nothing for FTP access. Is there something missing?
Will
Will
