Sand clock bizhub 601
  • aleksander
    • 378
    Hi all,
    Anyone have experience with bizhub 601? When I turn on the main and sub power switch, sand clock occured and KM logo not appear. No warming up, only cooling fan on OACB turn on. The machine cannot be used. I've already check the DC power supply unit and it's normal.
    Anyone please help me for the solution.
    Thank you.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • Driti
      • Jan 2008
      • 10
      any help for this case please, i have the same problem....but on my case I listen only the cooler and bizhub 601 is rebooting
      • mo0651
        • 1054
        could be a corrupt cf card. use the reformat procedure in the manual and suggested by tech support.
        • Driti
          • Jan 2008
          • 10
          any help for reformat procedure of cf card? Because when i connect it to the computer all computer freeze...
          • Gaffers01
            • May 2011
            • 335
            I have come across this problem 3 times in the last 18 months on colour boxes,
            Once i did a NVram recovery and the machine was fine, the other 2 i had to replace the PWB-MFP board.
            • TheOwl
              • Nov 2008
              • 1732
              If you are a Konica Minolta Autorised rep, then have a look at the bulletins. Sometimes its the CF Card becoming corrupt or it can also be the logic board.
              In the case of the logic board, ICP 12 - 14 might blow because of a short in on of the trays caused by the tray lift wearing through the wiring harness for the paper size detection pot. The quickest way to determine if this is the case is to check continuity on the ICP's on the logic board (I'm pretty sure its the logic board, but the one at the bottom left of the machine when looking at the rear or the machine). If any of these have blown, then you will need to check trays 3 and 4 for a worn harness under the tray lift.
              • suso73os
                • 38
                There is a service note:
                The display will not continue beyond the hourglass screen at power up.
                [Solution]
                PROBABLE CAUSES:
                1. Corrupt System and/or Image CF card Boot ROM file.
                Update the CF card Boot ROM file (bizhub 600/750) or System Boot ROM and Image Boot ROM files (bizhub 601/751).
                2. A failed or corrupt HDD.
                Physically disconnect the HDD from the machine and reboot. If the machine comes to ready and is operating, the HDD has failed. If, after reconnecting the HDD, you can enter the Service Mode, try formatting the HDD to recover it. If it cannot be recovered, replace the Hard Disk Drive (HD-503 - Item #15NL for bizhub 600/750 or HD-510 - Item #A0P7WY1 for bizhub 601/751).
                • remati
                  • 149
                  Re: Sand clock bizhub 601
                  CF card certenly...
                  -do not format it ...just delete ......if you format the, card you will kill it....
                  -after delete the, card , copy/paste de new firmware,to it
                  -if the card is corrupt you must ask for a new one to the fctory (konicaMinolta original card)
                  • aleksander
                    • 378
                    OK thanks all. CF card problem.
                    • Driti
                      • Jan 2008
                      • 10
                      Can I have a link for downloding CF card firmware, which is the last one?
                      • remati
                        • 149
                        • Driti
                          • Jan 2008
                          • 10
                          I have authorized access on KM site but firmwares there do not have the files i see on cf card, can you tell me which is the file...
                          • kronical
                            Kronic Copier Ninja
                            • Nov 2009
                            • 230
                            Originally posted by remati
                            CF card certenly...
                            Great, so how do you delete/copy files to the CF card if it can't be read by Windows due to it's format???
                            • HoonBoy
                              • May 2011
                              • 130
                              It can be seen in windows...if you can't it must be really defective...Before you put a new card, make a backup from all the files from the new card, and you can use it to copy those files on a CF card with corrupted data...If you are able to copy the folders NVRAM, SET and ADJ folders from the "old" CF card, you could paste them later on the "fixed" or new card, and you will have your settings and address book back...worked for me so far...
