if the black exit belts are hooking the white plastic parts, then the belts need to be tightened up. Open the top door and look down to the plate between the belts and there will be a screw. Loosen the screw and the belts will be tensioned up by springs in the assembly. Thighten ithe screw back down and away you go.
Bizhub C450 - Malfunction C11A4
misery90
Re: Bizhub C450 - Malfunction C11A4
This is the problem and the solution. I've been banging my head on this for a week now.
Thanks!Comment
