Konica minolta c500 pro fake jam code after paper exits
  • copierlady
    • 338
    Reposting this without the finisher code that i previously posted it with.
    I removed the finisher and the i still have the same problem. The machine is giving a jam indicator, as soon as the copy leaves the machine. It tells you to open lever #11 and roll "b" roller. There is no paper there as it has already exited. Any clues?
  • Socialist
    • May 2011
    • 9
    Re: Konica minolta c500 pro fake jam code after paper exits
    You need in 25 mode DIPSW11 bit 7 set to 1. After this you will see jam code on display.
    • Cantechman
      • Nov 2008
      • 228
      Sounds like it either is a sticky actuator, or maybe the sensor is shorting out. I would look for a actuator first, the spring can come unhooked or bent sometimes causing that sort of problem in general.
      • copierlady
        • 338
        Originally posted by socialist
        you need in 25 mode dipsw11 bit 7 set to 1. After this you will see jam code on display.
        thanks now i can view the jam code!!
        J 32-02 is the code i am getting.
        • Ianizer
          • Jul 2011
          • 380
          Just a crossreference link for the old thread.
          http://www.copytechnet.com/forums/ko...7-25-code.html
          -I
          My name Peggy.
          You got problem?
          • MILLER4157
            • Feb 2011
            • 48
            After the fixing paper exit sensor
            (PS17) is turned ON, reverse paper exit
            sensor (PS19) is not turned ON within
            the specified time.
            check (ps19) to make sure that it is functioning correctly. it will be located on the left hand side of the fuser below the ducurler rollers when you pull out the process tray. you may also have a timing issue to where the fuser loop is not set correctly.
            • Rolandito
              • Aug 2007
              • 91
              Same problem with my C500..
              I swapped even ADU Unit....but still code appears...I changed to face up in exit option in copy mode and works....
              Even the face up option activated..with controller has the same problem...So... when print a document I change face up option in finishing mode...and machine works
              I am thinking is firmware problem...I dont have files at this time....I will try next week when I got the files
