This is a problem machine thats been haunting us for a while with this strange issue...
The machine will ghost jam from all trays as soon as you hit the start key to make a copy. Every time and all the time.
I have replaced the PF clutch, PF gears and the shaft holder assy for both trays. This is not a mechanical problem because the PF motor M9 does not even come on( even in 47 mode) Everything thing else checks out: Dev motor, main, clutches, solenoids etc. We even swapped the Dev and PF motor around - NC. The PRCB does seem to be the next place to check but we did not find any blown ICPs. Any ideas?
