Dry prints
  • ffashe
    • May 2025
    [Misc] Dry prints
    Help! Can anyone tell me how to get glossy prints on card stock on my c500. The prints come out so dry it looks bad and I cant find any settings for paper on the machine. Turning the Gloss on does not help.
    Please help.
    Fortune
  • JustManuals
    • Jan 2006
    • 9838
    Re: Dry prints
    Why don't you RTFM.
      • 22930
      Re: Dry prints
      Did you expect them to be wet? =^..^=
      • ffashe
        Re: Dry prints
        Originally posted by manuals4you
        Why don't you RTFM.
        I am sorry, what does that stand for?
        Fortune
        • ffashe
          Re: Dry prints
          No, just a bit glossy!!
          • nmfaxman
            • 1702
            Re: Dry prints
            Use a Glossy card stock and feed it through the bypass tray.
            • 10871087
              • Jan 2005
              • 1143
              Re: Dry prints
              Fortune
              RTFM stands for Read The Fine Manual (most technical types use a different F word)
              What type of paper are you trying to copy onto? Are you using a glossy stock?
                • 22930
                Re: Dry prints
                What media type/weight?
                • ffashe
                  Re: Dry prints
                  100lb and 80lb gloss cover but I get the same results and the bypass tray makes absolutely no difference.
                    • 22930
                    Re: Dry prints
                    I doubt that the 100# cover is within machine specs (270 gsm). The 80# cover should be close to the maximum (218 gsm). What other media type choices do you have? Try the heaviest/thickest.
                    According to the documentation 140# index (252gsm) is the heaviest Bypass tray media, and there is no mention of glossy stock. See: http://kmbs.konicaminolta.us/main/co...hubproc500.pdf
                    Glossy stock is always the most difficult to fuse properly, and you've got really heavy stock. Is this laser paper or inkjet paper? 9 times out of 10, when someone hands me glossy stock it's inkjet paper. The heaviest laser gloss I've used successfully is 32lb bond (116gsm) on other machines.
                    And no, it's NOT OK to use inkjet paper. =^..^=
                    Last edited by blackcat4866; 07-13-2011, 01:46 AM. Reason: found the machine specs
                    • ffashe
                      Re: Dry prints
                      Thanks Black Cat,
                      That helps, it seems I am working with sheets above the specs of the device.
                      Thanks again.
                      Fortune
