Shadow image on print - why?
  • empiru
    • Feb 2011
    • 229
    #16
    Re: Shadow image on print - why?
    Ok, my last idea (I guess) is to swap the transfer belt unit between the 2 copiers (you said there are 2, right?); then, if the shadow is still there, swap the fusing units and if it still isn't dissappearing, I think there's something wrong with that drum you installed.. By swaping the parts, you can isolate the problem easier, in this case, when you get help from a long distance, on the internet . Only make sure that you inter-change the parts back again, on their original copier, so to say..
    I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
    • kingpd@businessprints.net
      • 921
      #17
      Did you try adjusting the laser beam intensity?
      • Merv
        • 63
        #18
        One unit is Prince Rupert and the other is in Terrace, about 100 miles apart, so immediate test parts swapping isn't that easy, but we have done it. I have an extra transfer belt (old one).
        No King, I didn't adjust the laser intensity (I don't think). Where do I find that function?
        Here is another image, You can see it seems as is some black is repeating itself cause I can see it off the edges of the image area. Does this helpkonica copy.JPG
