Misfeed detected jam c451
  • oscar
    • May 2010
    • 45
    I'm in this jam featuring a C451. I will say what has changed: the unity of full duplex, and the board PFTDB PRCB. someone help me.
  • Gaffers01
    • May 2011
    • 334
    Re: Misfeed detected jam c451
    Did the machine have a finisher on it when this problem started?
    • oscar
      • May 2010
      • 45
      was the finisher, but with or without the finisher of this jam the machine. how to have a master reset on the machine?
      • Gaffers01
        • May 2011
        • 334
        You need to plug the finisher back in, and open covers and switch On machine.
        This should then reset machine.
        • oscar
          • May 2010
          • 45
          done the way you said and still the same message.
          • empiru
            • Feb 2011
            • 229
            Hi! I don't think your machine is indicating a jam in the duplex unit, more like in the fusing unit. I think you should look there closer to see if all the sensors/actuators are in the place where they are supposed to be. I think this problem has a simplier solution, I don't think you should have changed the duplex and that board... Let us know if you find something wrong there.
            I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
            • BIG PAPA
              Da Boss
              • 234
              In the Service mode go to couters and Jam history. What code is being recorded?
              sigpic
              • minimerlin
                • 851
                Have a look at the exit sensor, it is on the RH door at the top by the yellow coloured guides. It is easy to knock the sensor mounting so that the actuator does not cut the beam.
                Please do not PM me without asking first.
                • JustManuals
                  • Jan 2006
                  • 9838
                  This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
                  Paul@justmanuals.com
                  • Ianizer
                    • Jul 2011
                    • 380
                    ADU sensor could be plunged. Old C350 failing, but see it on C650 series occasionally.
                    -I
                    My name Peggy.
                    You got problem?
                    • SCHWARZ
                      • Jun 2011
                      • 47
                      try clean ADU section and ADU sensor from paper dust
