C6500 scan and copy background
  • mr_drucken
    • Jul 2025
    I had a problem in machine C6500..if I copy or scan original,appear background magenta on paper and on file for reesult scan, but if I do printing even from file or test pattern result is good. any idea to solve this problem? thanks for support,..mr_drucken
  • inutelkamo
    • Jul 2011
    • 143
    Re: C6500 scan and copy background
    here are some point to be check:
    Scanning and Copying uses the scanner area, please check mirrors at ADF or scanner area.. mirrors and crystals..
    In printing, its okey right? since it dont uses the scanner of the machine..
    Good Luck
    • empiru
      • Feb 2011
      • 229
      See if there is a "cable" looking like this Google Images that goes from the CCD to the back of the unit and plugs into the Image Processing Board (If I recall correctly); try to reconnect that cable at both ends; it may solve you're problem. I hope this helps!
      I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
      • Ianizer
        • Jul 2011
        • 380
        If the controller is Fiery, I'd first reboot, get all PM, FW & Fiery SW & patches up to date;
        then recalibrate, being sure to calibrate the scanner. (Install CWS 5.3 if you already haven't.)
        I know that's just basic stuff, but it would rule it out.
        -I
        My name Peggy.
        You got problem?
        • mr_drucken
          thanks all for your support, problem had been solved by replace ccdb with new one,and the problem is come from ccdb due to electrical grounding is high, and make it shorted.thanks...
