km cf2002 toner adding
  • Northwestservice
    • Jan 2011
    • 140
    is there a drive mechanism that adds toner form the hopper to the dev unit and do they plug up have a magenta toner adding problem manual does say much?
  • empiru
    • Feb 2011
    • 229
    Re: km cf2002 toner adding
    Man, is that google translate?? I can't understand what you need... do you want to know if you can manually add toner? You can do that in Service Mode, Image Adjust, ATDC Toner Supply. For Service Mode, enter the Utility menu, counter list, then press the following keys: Stop -> 0 0 -> Stop -> 0 1.
    I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
    • Northwestservice
      • Jan 2011
      • 140
      no it just normal english lol i have machine that is not adding mag toner i can manually (by hand ) dump some toner into drum unit and it works for a while them seems to run out of mag. on the copies??? no error codes
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
        Paul@justmanuals.com
        • empiru
          • Feb 2011
          • 229
          Ok, understood now Please pull the Magenta IU out and make sure it has got a little plastic "lid" right on top of the hole where the toner goes; it should be hold back by a little spring.. is it there? If that is missing, the machine won't supply on toner; if you don't understand what I mean, pull out the Magenta IU and the Yellow IU and compare them, see if there is any difference around that place..
          • Northwestservice
            • Jan 2011
            • 140
            yes i do understand and the little doors and springs are there on all of the dev units.. i find it odd that with customer adding a little toner by hand every 50 copies and 1 time had and error code for overtone its working with no other codes??
            • ESA
              Is the toner hopper full now? If yes than stirring motor maynot be operating correctly. I would try a 100 magenta copy / print and watch to see if hopper is moving. You may need to vaccum it out and look for blockage. I would also try the service mode add toner and watch.
