konica c360... poor copy quality
  • docteceng
    • Jul 2011
    • 12
    Any help much appreciated, I have a customer where we changed the dev units . everything was ok. but few days later the copy quality started to become poor.. now there are no solids on in the black text. but colours seem to be ok... when you produce a sky shot instead of being black it is light grey with banding on the copy...should we have performed some sort of setup procedure after installing the dev units ..and if so anyone have an idea how we can get the machine back on track .. once again many thx in advance..
  • empiru
    • Feb 2011
    • 229
    Re: konica c360... poor copy quality
    Hi! I admit I have no experience with the C360 series, but I am 100% sure you should have done some adjustments... I can tell you, in the Minolta CF3102/2002, Konica 8020/8031, Bizhub C350/C450 you have to run the GRADATION ADJUST when you install new developing units; before that, you have to make sure the background voltage margin for each color is set to 0. Try to find this adjustments in the service menu of that machine, if they are there, conduct them. Good luck!
    I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
    • AjitN
      • Mar 2009
      • 287
      Hi
      Check for toner, may be compatible or very old stock.
      Also check for Dev. Assy which you have replaced. Even though dev. Assy. fixing screws are located correctly, Toner inlet pipe does not get seated fully as it is flexible.
      Regards
      Ajit
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        Is this dev completely new?
        I'd dig up the service manual and check anything regarding calibration, dev roller fatigued. They've been using tons of K's.
        Idling colour developers are not healthy developers.
        • inutelkamo
          • Jul 2011
          • 143
          Good day.. all new dev units??
          Please do some calibrations..
          The I/O value of old developing unit is carried to the new ones..
          It is a must i think to do calibration every replace of dev units, belt and imaging drum, but some are just ignoring it..
          Set background voltage first to zero and find in image adjustment the gradation adjust..
          I know you know how to calibrate..
          Good Luck!
          • JustManuals
            • Jan 2006
            • 9838
            This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
            Paul@justmanuals.com
            • boanda
              • Feb 2011
              • 79
              Good Luck!
              That is the first think u MUST do, second, if the quality is still poor, replace dv unit!
              I have had a machime comes from factory with low developer ! and musted to replace with newone. 3-4 machines(c220 only)comes with this problem, but u newer know...maby u got premium,too
              I hate c220/280,360 series!
              • inutelkamo
                • Jul 2011
                • 143
                hahaha! does this have lot of problems?? i have an incoming 280 unit installation probably nxt month..
                • BIG PAPA
                  Da Boss
                  • 234
                  Dont worry too much. I have setup and installed many of this series and have yet to have any problems.
                  sigpic
                  • AjitN
                    • Mar 2009
                    • 287
                    We have faced this problem few times, happens only in case of black DV Unit. When waste toner bos in fitted in the machine, during transportation lot of Black dev. slips in to waste toner box as outlet is open. Especially if machine gets tillted towards front side. We take out the dev from WTB. and adds that in dev unit, no need to replace the unit at all.
                    Hope this may help in few cases in future.
                    Ajit
                    • boanda
                      • Feb 2011
                      • 79
                      Ajit
                      Yes, u explained what I wanted to say(didnt because of mu bad english)
                      But we instal machines in front of customers, because they request that, and I cant add developer in front of them,so i must replace dv unit and repair the newone when I back to firm
