Fiery X3e System Software CD
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Were you able to download the file or do we need to try another method?
    Now into Ip TV KODI Boxes
    • baret
      I can't succeed. Displaying this message :" An error occurred opening that folder of the FTP Server.Make sure you have permission to access that folder."
      • pepper38_cnd
        • Aug 2005
        • 1075
        If you use Yahoo or MSN messenger... message me now and i will transfer the file... pepper38_cnd for either
        • RockETop
          Curmudgeon at large
          • Apr 2007
          • 171
          #19
          I hope you have a parallel port.....
          • baret
            #20
            I have a PC with Windows 98 and parallel port
            • doctech
              #21
              I am in the same boat with a Minolta CF1501 color copier. I need the system software to redo the hard drive. Where do you get it?
              • Sbarro
                • 176
                #22
                Hallo. We have a Di551 with X3e and some manuals with Pi6500 state.
                System software on the fiery is in german language and i need to change this.
                Besides i can't enter the setup for fiery (password).
                I believe it's the same version ?. Can you help me ?
                "A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
                What do you despise? By this you are truly known"
                Guess who
                • copy shop
                  • 40
                  #23
                  Di551 with X3e and some manuals with Pi6500-PRO?
                  First off I have read at the monolta site that the 6500 Pro controller can only be attached the the DI-650 and that is the only model I have actually put the 6500pro onto myself....I beleve the e-6500 series is used for the DI-551 ....with that in mind
                  You say your System software on the fiery is in german language?
                  It will depend on who and where is was installed, but/and also if your using the 6500PRO-? external print controler unit; it should have a small screen and menu with buttons on the front of it, and when you turn on the copier, wait about 10 seconds later turn on the print controller and be sure to watch the little screen on the print controller for the set up menu; and choose setup and from all those menus you can change the language, time and everything; ( get out your 6500 books to to which buttons are for what funtion )
                  Once you set up the ip address from the little buttons, you will be able to access the ip address from your computer through your browser, then you will be able to ALSO set up everything this way through the browser instead of the controller screen. Thie second way takes the least time, but you still must configure the ip add into the controller screen before you will be able to access it with the browser. One more point, after you get it all set up, the port number needs to be 9100 to be able to print from the computer to network.
                  and unless someone has changed it the password should be 0000 - ZEROS
                  I'll look for a little more info for you on this for you tomorrow.
                  Hope some of this helps for now
                  Tammy
                  • Sbarro
                    • 176
                    #24
                    It's on the back of the machine and has no display.
                    When you switch on control panel to Printer Mode you read all info about the Fiery. It's X3e v1.1. Thats all.
                    We got some papers and manuals with it and on 2 of them state Pi6500 and there is not one word about 6500Pro.
                    We got it from German thats why
                    Guess who
                    • Humedss
                      #25
                      fiery
                      I think efi makes all fiery boxes.
                      • pandorabox
                        #26
                        Fiery X3e System Software CD need
                        For reinstall CF2002
                        Plase help.
                        • copy shop
                          • 40
                          #27
                          Sorry I don't Have the cd For reinstall CF2002
                          I only have Fiery X3e System Software CD for the Pi6500 pro system.
                          I have never had to do the cf2002
                          You may be able to try the myprintcontroller site
                          ( chip programmer banner at the top of the copytech page)
                          And put in your request for your desired controller software.
                          • pepper38_cnd
                            • Aug 2005
                            • 1075
                            #28
                            Hey just send me an Email . I'll get you what you need no charge unless the file is so large it can only be delivered on dvd. thanks Tammy for the vote of confidence, business is good.
                            info@iuresets.com
                            • copy shop
                              • 40
                              #29
                              Hi There !
                              No Problem....Glad to see all is going well for you !
                              Tammy
                              • uscovu
                                #30
                                cf 1501/fiery x3e controller
                                hi
                                I have a little problem with my printer Minolta CF 1501
                                When I turn on the printer starts to warm and he block's, the display show "system booting, please wait..."
                                and....that's it
                                So...what do I have to do? There is a back-up on the HDD's controller?
