bizhub c450 c3201
  • ESTANISLAOWENENTON
    • Mar 2025
    bizhub c450 c3201
    hello
    putting heavy paper in the copier, I mark this c3210
    I can not print thick paper
    appreciate your help
  • Ianizer
    • Jul 2011
    • 380
    Re: bizhub c450 c3201
    What weight heavy stock? (If giving poundage, what type: Bond, Index, Cover, etc; Coated or Uncoated)
    What tray?
    What setting?
    What total copy count?
    Any problems with plain stock?
    Are you an end-user or technician?
    -I
    My name Peggy.
    You got problem?
      hello
      technically I am
      I can not print anything
      the mere fact of placing the machine in thick paper 1, on plain paper giving problem
      • Ianizer
        • Jul 2011
        • 380
        Originally posted by ESTANISLAOWENENTON
        hello
        technically I am
        So...
        Attempt to print anything, machine pops a C3201...
        Simply select Thick1 for any tray, the machine pops a C3201...
        Possible, M11 Fuser Drive problem.
        Check connectors at motor & at PRCB.
        To troubleshoot, M11 is interchangeable with M1 Drum Drive. If a motor problem C2202 fault will present.
        If not, look to PRCB as bad component.
        Before doing any of this, I'd remove and closely inspect fuser and fuser drive.
        Gears and bushings have been known to fail, causing sieze.
        That's all I got for now without answers to my questions, my friend.
        -I
        My name Peggy.
        You got problem?
          hello
          technically I am
          thanks for replying
          Fortunately for me, the client has not realized
          wait for failure and review
          thank you very much for the excellent support
