Konica Minolta Bizhub c450 Unable to Configure TCP/IP
  • johnkuo562
    Tech
    • Jan 2008
    • 10
    Hello im not able to change the IP address or subnet mask for some reason. Noticed DHCP is set to on also and can not be turned off. Seems like its locked guys so I hope you can help.
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    Do you mean it won't allow you to turn it off, or it won't stay off?
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
    • peter lynn
      • Dec 2007
      • 27
      go in thro tech rep mode
      then switch off dhcp and then you can change i/p address etc
      • mikeena
        Branch Technical Manager
        • Mar 2007
        • 219
        well thats a good one it you can not change it at all. do you now if there is enhanced security turned on, or possiably a dipswitch is set.
        • Scott_Lewis
          • Mar 2007
          • 519
          Do we even know which controller he has on this m/c?
          John, how many ethernet jacks are on the right side of the copier? You will notice the copier has an overhang at the back side. Is there another controller mounted under the overhang?
          • johnkuo562
            Tech
            • Jan 2008
            • 10
            Whats tech rep mode?
            Tried calling the place were we leased the copier and they want to charge me for someone to come out to just change the IP address. Now if the printer was jamming then I would have no problem calling for service but not for changing the IP address. If anyone can tell me about the dip switches I will give that a try. I have no idea where the dip switches are located also. Thanks for your response guys your the best
            • RockETop
              Curmudgeon at large
              • Apr 2007
              • 171
              Yup...
              • fernan
                • Jan 2008
                • 61
                disable the dhcp then switch off and on the machine
                • johnkuo562
                  Tech
                  • Jan 2008
                  • 10
                  Unable to disable DHCP
                  When I enter the network setup I can not turn off DHCP. I tried touching the screen and nothing happens. Seems like its Locked so anyone know anything about the switches or a way to unlock the TCP/IP settings?
                  • pepper38_cnd
                    Field Service Manager
                    • Aug 2005
                    • 1075
                    Have you tried changing the settings thru the web utillities?
                    I would guess maybe you cannot even access the web utillities?
                    If this is the case, then probbably enhanced security is enabled.
                    My suggestion is pay the service call and have the machine propperly configured by someone who knows what they are doing, if this machine was setup propperly and working fine there would be no real reason to change the ip address unless there have been changes made to the network? If this is the case I guess you could always work backwards and try and undo whatever changes have been made.
                    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                    Now into Ip TV KODI Boxes
                    • mikeena
                      • Mar 2007
                      • 219
                      so this machine can be set for the admin to have only certain rights thru enhanced security mode. me and another co worker where wondering that but we have upgraded all of this model into the 352 and so fourth so i could not test that therory.
                      • pepper38_cnd
                        • Aug 2005
                        • 1075
                        It appears the attachment feature is not working. You can get the Enhanced security users guide from my ftp.
                        ftp://pepper38.no-ip.org/bizhubC450S...sUserGuide.pdf
                        User: pepper
                        pwd: pepper
                        Note enhanced security can only be enabled by a qualified tecnician.
                        • dogsbody
                          • Jun 2007
                          • 289
                          I hope whoever set it up didn't leave DHCP on and then set up the print drivers to print to an IP address rather than the machines host name, thus generating a chargable call every time DHCP assigns a new address.
                          The force will be with you always.
                          • pepper38_cnd
                            • Aug 2005
                            • 1075
                            dogsbody has apoint! If this was not set up the way the customer wanted it, or if the the customer didn't know better and let them configure it however they wanted it, then if that configuation causes a problem in the future it should not be at the cost of the customer.
                            • mikeena
                              • Mar 2007
                              • 219
                              what it sounds like to me is he just ought the machine used and decided that it would cost to much for a tech to come out and have them fix it. i dont think he bought it from the company and they did this.
