C253 + FK502 protocoll error
  • habik
    • 2013
    Can't receive faxes on FK502, sending is OK.
    Latest FW and when receiveng it just pops Protocoll Error..any suggestions?
    Firmwares HERE
  • habik
    • 2013
    Re: C253 + FK502 protocoll error
    OKAY
    here are some codes
    T81-
    T81 Call control
    Dial Tone detection NG when CML
    is turned ON at calling
    The line may not be connected.
    Check the line connection status.
    R07-
    R07 Reception
    Image information does not come
    in image information waiting.
    The line may be disabled because
    the user on the remote station disconnected
    it.
    switched off ECM..and had slight improvement, lowered TX/RX speed to 14k bps , not much of improvement, Initialized fax board to default, slight improvement.. took the whole board out and waited for 5 min than slapped it back in. worked for a while could send and could not receive, than could receive and not send..frustration kicked in..until
    customer complained about internet connection...asked where is their MAIN connection socket and found that fax line is run of broadband line through adsl filter. So my biggest suspicion is the actual BB line,
    Have you come across a problem like this? Thanks for suggestions. M
    Firmwares HERE
    • Spidula
      Konica Minolta Technician
      • 83
      Originally posted by habik
      OKAY
      here are some codes
      T81-
      T81 Call control
      R07-
      R07 Reception
      it.
      You can get patch cables for fax kits running through broadband filters. I had this a while back and a patch cable sorted it!
      • habik
        • 2013
        http://www.copytechnet.com/forums/ko...col-error.html
        Thanks Spindula,
        I think the actual ADSL filter is causing the issue, client has got new tel. line cable going from filter to copier, and there is just the standard British Telecom socket on a wall, so not much I can do except the filter, which is clients responsibility anyway..
        Will see what happens when they buy new one and fit it in.
        Thanks for your effort. Will reply if there was improvement so we can close this thread succesfully.
        Firmwares HERE
        • Mooseface2r
          • Jan 2011
          • 114
          Hi did changing the filter resolve this?
