Bizhub C353 "License Management Error"
  • Jorvikps
    • Dec 2014
    • 37
    #16
      • 14775
      #17
      Re: Bizhub C353 "License Management Error"
      I agree with Jorvikps. I have had this issue three times and all three times I was able to solve it by replacing EEPRom. Quick, easy and cheap.
      • M3HR4N
        • Jun 2015
        • 34
        #18
        OK for clarity, if you have a problem with "License management error" in _ANY_ machine type, please follow procedure below.
        1. Go to the service mode and change machine serial number to A0R6021006374 (must be uppercase)
        2. Reboot the machine (turn off/on main power switch)
        3. Go again to the service mode, then [STOP]->[9], then [License Management]->[Initialize]
        4. Use following initialization code: 2VRA4-UGGA2-Z2H4K-7AVUH-F58SW-J2Z7U-QVKVK
        5. Reboot machine again
        6. One more time go to service mode and set back your original serial number
        7. Last reboot, and you should have no error
        ANY means:
        Bizhub 421/501
        Bizhub 601/751
        Bizhub 223/283/363/423
        Bizhub 552/652
        Bizhub 224e/284e/364e
        Bizhub C203/C253/C353
        Bizhub C220/C280/C360
        Bizhub C224/C284/C364 also 'e'
        Bizhub C454/C554 also 'e'
        and so on...
        Did anybody try this? Did it work?
        • fishleg
          • Mar 2009
          • 426
          #19
          I did on a c253 worked for me . Amazing bit of info thx very much.
