Bizhub C353 "License Management Error"
  • D Colour
    • Oct 2008
    • 216
    Hello
    We have had to perform a NVRAM reset on this machine. Now when it boots up, it will display the message "License Management Error."
    Can anyone tell me how to sort this out. We have gone through the setup procedure and double checked the serial number is correct.
    James
    Everything that has a beginning, has an end.....
  • emujo
    • Jun 2009
    • 3009
    Re: Bizhub C353 "License Management Error"
    I've only seen the license errors (false) on the B&W mfps. We had a C550 that gave us this when SYS bd was replaced, but it did have a LK-XXX installed prior. You may try taking the firmware down to the earliest version, and then back up in increments applying the HDD firmware ups where applicable. Emujo
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • SPBE
        • Sep 2010
        • 70
        Subject:
        What to do if a "License Management error occurred" message is indicated after upgrading firmware or replacing the NVRAM or EEPROM board.
        Description:
        "License Management error occurred" message.
        Solution:
        Whenever this message is indicated, it is necessary to perform the Repair operation (see attached "Repair Procedure").
        Notes:
        1. When replacing the NVRAM or the EEPROM board, if the parts are replaced with used parts, the License Management error condition cannot be resolved by performing the repair operation.
        In this scenario, Initialization would then be necessary and support must be contacted.
        Additionally, if both the NVRAM and the EEPROM board are replaced, Initialization will be necessary.
        IMPORTANT: Perform the Repair Procedure first, then the Initialize procedure. If initialization is required, collect the following information before calling support:
        • If i-Option was ever licensed on the MFP and if the additional 512MB of memory was ever installed at any time
        • The firmware level prior to the machine being upgraded to version 88 (bizhub C353 and bizhub C650 series models only)
        • If the machine ever had firmware version 85 or 86
        • A history of recent NVRAM or EEPROM board replacement
        • Obtain a machine Management List and have it ready to attach to the ticket.
        • A screenshot of the message returned from the LMS if "Repair" was unsuccessful
        • A "Request Code" from the MFP and the S/N must be obtained in order to start the "Initialization" procedure (see attached "Obtain Request Code" and "Initialize")
        • bronco31
          • Aug 2009
          • 174
          wow.. old thread.. but im working on a good copier! Bizhub601... upgraded firmware (and then it asked upgraded HD) now "License Management error" cant find the repair procedure in the manual
          any body know how to "repair" ?
          thx..
          Guy
          • allan
            RTFM!!
            • 5462
            It works with the LMS server in Japan. Halve of the time it does not work and you need to motivate why you need the codes to repair the machine. i have learned to live with the messages.
            The OEM does not like you to fix an old machine with another old machine. And as of late not to fix one machine with another machine at all. Must use new boards or properly reset boards.
            Can you log into the LMS site? https://lms.konicaminolta.com/license/KM/support.aspx
            There is a section in the manual that describes the procedure to fix the error after NVram replacement. Use the manual for this.
            And there is a section that explains the HHD problem on the B601.
            Did you use the CF card recovery procedure?
            Whatever
            • bronco31
              • Aug 2009
              • 174
              i have not wiped the CF card to base... and then all the way back to version 20...shd i try that? i assumed the LM error is generated from the NVRAM.
              No unable to log into their LM System server... we lost KM support when they decided to dump us as we couldnt sell 5 million dollars of equipment per year!
              Thx Allan
              • allan
                RTFM!!
                • 5462
                there is a recovery firmware that would take it to an special fw version.
                Whatever
                • emujo
                  • Jun 2009
                  • 3009
                  Removal of the License management error can only be done through LMS support. That being said, there was a poster a few weeks back that said he had a "magic" serial number and repair code that would fix any license error. I'm sure it wouldn't hurt to try, but, having access to KM LMS server I just go that route. Emujo
                  • rysiulg
                    • Dec 2014
                    • 21
                    thx..
                    Guy
                    I've found this on other site of copytechnet.com with same problem
                    OK for clarity, if you have a problem with "License management error" in _ANY_ machine type, please follow procedure below.
                    1. Go to the service mode and change machine serial number to A0R6021006374 (must be uppercase)
                    2. Reboot the machine (turn off/on main power switch)
                    3. Go again to the service mode, then [STOP]->[9], then [License Management]->[Initialize]
                    4. Use following initialization code: 2VRA4-UGGA2-Z2H4K-7AVUH-F58SW-J2Z7U-QVKVK
                    5. Reboot machine again
                    6. One more time go to service mode and set back your original serial number
                    7. Last reboot, and you should have no error
                    ANY means:
                    Bizhub 421/501
                    Bizhub 601/751
                    Bizhub 223/283/363/423
                    Bizhub 552/652
                    Bizhub 224e/284e/364e
                    Bizhub C203/C253/C353
                    Bizhub C220/C280/C360
                    Bizhub C224/C284/C364 also 'e'
                    Bizhub C454/C554 also 'e'
                    and so on...
                    • bronco31
                      • Aug 2009
                      • 174
                      thx! cant wait to try this.... get rid of that nag screen!
                      • rysiulg
                        • Dec 2014
                        • 21
                        There is also possibility to get repair code in few seconds.
                        On site: https://lms.konicaminolta.com/license/KM you must register and after login as CE you can generate repair code for your machine in few minutes
                        Found on Copytechnet forum
                        • copierwhisper
                          • Mar 2013
                          • 78
                          I've been down that road a couple times. In each case the product key code was required to resolve the License Management Error because the i-option had been installed. If they are not using the i-option you can request a release code or if they are using the i-option request a repair code from KM via LMS. You must be certified on that machine in order to request the code.
                          • rysiulg
                            • Dec 2014
                            • 21
                            I've made and download repair code after successfully registered. I'm not certified technician of KM nor any dealer. Registered on my own e-mail address...
                            LicenseManagementError doesn't appear only by i-Option active. If sombody reset nvram (eg with CF card) the switch in NVRAM change that somenthing is wrong and for that reason is Licence Management Error even if you never installed i-Option.
                            • bronco31
                              • Aug 2009
                              • 174
                              link goes nowhere
