C280
  • AlSyed
    NewBee
    • Aug 2010
    • 41
    [Misc] C280
    I got this BizHub C280 Brand New. Set it up and printed out the report which is fine. Made copy from glass and got these fine lines apart about 1/2 inch. Cant figure it why its printing fine but giving these lines when making copies. Followed the setup procedure 2 times but nothing changed. Any help will be appreciated.
    Tnx
  • mo0651
    • 1054
    Re: C280
    colored lines? Get an updated version of setup. they missed a step and that is why you are having trouble. Including touch screen.
    • MILLER4157
      • Feb 2011
      • 48
      Re: C280
      if it is a new install. make sure that you have run all of the proper calibrations. lines could be produced from not running new drum/ dv life unit detect or running gradation.
      i agree with mo0651 you probably skipped something in the setup.
      • AlSyed
        NewBee
        • Aug 2010
        • 41
        Re: C280
        Tnx Guys, Ran the Gradition 3 times in every step. The detection of new DV/Drum is in which manu. Please advise. Sincere Regards to you all.
        • MILLER4157
          • Feb 2011
          • 48
          Re: C280
          new article life is detected by the chips on both the developer and drum units. so you should be good. are you still having lines?
          • ezzysi
            • Oct 2008
            • 78
            Re: C280
            Had exactly the same issue today on a new C220 PDI, thin coloured lines all over page approx 20mm apart.
            Re-followed the PDI instructions WORD for WORD and the fault was gone.
            Simon
            • AlSyed
              NewBee
              • Aug 2010
              • 41
              Re: C280
              Hello Friends, I am agree that the mistake was not to follow the instructions "WORD TO WORD" and "STEP BY STEP". I was entering time as 12 hour clock as I was coinsidently doing both setups after lunch and entered time as 1:45 whereas it should have been 13:45. Machine is making nice copies.
              One more setup is how to increase image density from ADF. When I make copy from Glass its very nice but from ADF its little light.
              Again Thanks for all the friends for input and help on ADF issue will be appreciated.
