PC drum clear bizhub C360 & C280
  • aleksander
    • 378
    Hi guys,
    I want to replace 3 PC drums (CMY) caused of "please replace PC drum unit (C)" and 2 other color PC drum displayed on bizhub C360 & bizhub C280. Anyone know how to reset PC drum counter? Because after replacing the drum unit, "please replace PC drum unit (C)/(M)/(Y)" still occured. Any solution?
    Please help.
    Thank you.
  • Ianizer
    • Jul 2011
    • 380
    Re: PC drum clear bizhub C360 & C280
    Did you replace them with factory new units taken from a sealed box?
    -I
    My name Peggy.
    You got problem?
    • aleksander
      • 378
      -I
      I replaced the PC drum unit (DR311) taken from other MFP (bizhub C360 new machine) because I don't have PC drum stock in my warehouse. I've already ordered the PC drum unit (DR311) and still waiting until now. So I tried to replace the drums unit using another new C360 machine.
      • Ianizer
        • Jul 2011
        • 380
        Then they've already been reset.
        Some people replace the chips... or perform some such magic... I don't.
        Might be a special firmware (a la C550 GS6-R6) to allow you to eliminate the IU warning.
        -I
        My name Peggy.
        You got problem?
        • aleksander
          • 378
          -I
          But unfortunately the pc drum taken from another C360 not resetting the pc drum life counter. ABout the special firmware, that's for C550 series? can it use for C360 series?
          • Ianizer
            • Jul 2011
            • 380
            I understand. If an imaging unit has been in another machine, it has reset in that machine and will not in another.
            FW is model specific. C550 was just an example. Special FW exists for that series that allows certain settings that will increase the IU yield.
            You'll need to research your model for any special FW that might eliminate the offending message.
            I don't know off the top of my head which designation it would be, if there is one at all.
            Okay, I did some research for you. It's outlined in bulletin #6901.
            Set the Unit Change for the IUs to Service.
            You may need to upgrade to the latest base FW & Movie Data.
            Good luck.
            -I
            My name Peggy.
            You got problem?
            • Darren King
              copiertech
              • 652
              If you are authorized KonMin service check out tech tip 954. It gives you all the details. This firmware allows you to set the machine so it will never display end of life messages for fuser, transfer belt, all drums and K dev unit.
              Hope this helps
              Darren
              • Ianizer
                • Jul 2011
                • 380
                Hope this helps
                Darren
                Thanks DK. Thought there might be a special FW.
                You lost me with 'Tech Tip 954'. Multi-line dealer, so my time on SSD is split... Can I get a hint where to locate it?
                -I
                My name Peggy.
                You got problem?
                • Darren King
                  copiertech
                  • 652
                  Hey I
                  Special firmware "PPLMUSBFlashFiles v1.7" is the file you want. It is a large file as it has firmware for machines that can be updated via USB (BH223-423, C220 series and C452-652) Thers are softswitches that need to be changed. You should be able to find them on the KonMin tech support website. If not let me know and I will email it to you.
                  Hope this helps
                  Darren
                  • boanda
                    • Feb 2011
                    • 79
                    I have been exchanged and all works fine, but in c220
                    • rrrohan
                      • Sep 2011
                      • 1977
                      go into advanced security in service mode and its no dev/drum stop
                      • aleksander
                        • 378
                        I tried many firmware but this problem still happened. But, is it possible that the problem is the chip in Drum Unit?
                        • sharkie
                          • 24
                          Hey I
                          Hope this helps
                          Darren
                          Hi Darren could you tell me does this firmware actually stop the replace IU message from being displayed or does it just allow the machine to continue to run once the units have reached their life?
                          Also cant find this tech tip on the cses website is there any chance you could mail me a link?
                          Many thanks
                          Hardy
                          • Albonline
                            • Sep 2008
                            • 1150
                            Many thanks
                            Hardy
                            It stops the life messages. read the bulliten as you must change some settings on the copier.
                            • dieselhead
                              Thanks for the PDF. The soft switch settings were made a lot simpler.
