Plz. Somebody. Anybody. C352 no light from display/op. panel
  • SKTeK315
    Walter
    • Jun 2009
    • 142
    What's up all ?
    Plz., no light from bulb. Contrast only does just that. Makes LCD ELEMENTS ON SCREEN GET DENSEER, (more visible & fade away when VR turned opposite. If it's not the op-panel then WHAT ???
  • Gaffers01
    • May 2011
    • 335
    Re: Plz. Somebody. Anybody. C352 no light from display/op. panel
    I think there is actually a lamp in the display, its the bit under the touch display with (White casing) that needs to be replaced.
    • SKTeK315
      Walter
      • Jun 2009
      • 142
      Originally posted by Gaffers01
      I think there is actually a lamp in the display, its the bit undeMoy the lamp. r the touch display with (White casing) that needs to be replaced.
      Not the lamp. Changed 2 then op panel. If not the panel or the bulb nor the ribbon cable, then...?
      • acusso1234
        Tecnico
        • Dec 2008
        • 250
        Check the connection of the silver connector on the right side of the machine. Sometimes give problems.
        ... In the minute that you're thinking of giving up, think about why you lasted so long ...
        • SKTeK315
          Walter
          • Jun 2009
          • 142
          Seems ok. It's only the display lamp that's effected. Nothing else. Contrast dims & brightens the LCD bits but no light
          • copytechman
            • Nov 2008
            • 966
            Likely blown icp on scanner board if you can see the screen but it's not backlit. Either repair the icp or replace the scanner board iirc.
            Regards!
            A.
            • SKTeK315
              Walter
              • Jun 2009
              • 142
              Regards!
              A.
              That's what I thought. Tnx. What's icp ? Is that the board behind & lower of the ccd ?
              • copytechman
                • Nov 2008
                • 966
                Yeah, hard to describe the icp exactly but if you've had dealings with them before you'll know what to check.
                Regards!
                A.
                • JustManuals
                  • Jan 2006
                  • 9838
                  Paul@justmanuals.com
